How to generate a DC voltage to the NI USB-6008 output channel?
I need to generate a 5V output to the NI USB-6008 output channel, but how?
(3,144 Views)
A simple DAQmx Write - single sample/single channel. A DAQ Assistant can be easily configured for this as well.
(3,135 Views)
Can you explain more specific? Where to connect task in and where to connect task out? Can you take a screen shot of a simple sample of daqmx write? The sample in labview itself is too complicated.
(3,124 Views)
Here is my email address: luoyuxiqq@sina.com. Thank you very much.
(3,118 Views)
