How to generate a signal like this on PCI-6202 DAQ card
I want to generate a signal like the one in the attached picture.
Which have inputs like
1. Frequency
2.Duty cycle
3. No of pulses
I have created a file which gives the signal like the other one in the end which has frequency of 200us and duty cycle of 0.5% that is 1us On and 199us signal off. Now i need to include some sort of condition that when the button is pressed then the signal of the require frequency, duty cycle and no of pulses is created as input by the user on the front panel, like the one which are first part of the signals in the picture below.
(2,960 Views)
I can direct you to this forum post as an example and see if it helps you out. It seems very similar
http://forums.ni.com/t5/Multifunction-DAQ/how-to-generate-digital-signal-from-PCI-6221-like-the-one-...
Rob W.
(2,911 Views)
