How to generate an averaged and filtered power spectrums using read from spreadsheet
I need to generate an averaged power spectrum and a filtered power spectrum using the read from spreadsheet function.
I had collected some data and I was able to use the read from spreadsheet function to generate a raw power spectrum by reading the power spectrum magnitude, and df of the power spectrum.
I really really appreciate for any help offerred.
Thanks.
(2,704 Views)
If I get it right, you want to make a statistics over your array of data... You can insert the data into array and use the VIs from Mathematics/Probability&Statistics For example: to determine the mean value, standard deviation etc...
I hope this make sense to you.
Cheers
Angel
(2,700 Views)
Hi Angel,
Thanks for your response. Actually, I want to plot the data in a graph, i.e. plot both the averaged power spectrum and the filtered power spectrum, amplitude vs frequency.
(2,690 Views)
Hi tronne,
So are you having problems accomplishing the averaging and filtering, or plotting the output of the functions, or both?
Have a great day,
Chris V
(2,676 Views)
Hi Chris,
I don't know how to plot the results that I have. I've saved the power spectrum data (using write to spreadsheet), but now I want to be able to read back my data and plot the power spectrum in a graph.
Hope you get what I mean.
Thanks for taking your time to help me.
(2,672 Views)
You can plot your data using XY graph. Something like this:
If your file a header, you have to remove using the Array subset function... 🙂
To make a filter just add a 'check' in the FOR loop, if the indexed value is bigger or smaller than Yo then take/use some other Yi...
Does this make sense to you?
Greetings,
Angel
(2,649 Views)
