How to generate pulses in Labview
Dear Sir,
Thank you all friends for your help and support.
I am rellay try hardly to use two counters to generate for me 6 rectangular pulses (0,15m sec high and 7,35m sec low)and then two wait 2 seconds and again generate 6 pulses...etc, but all of my work do not give any result.
I try to search and find the examples also but I could not, so please, I ask any one who has the time, please write this program to me and send it to me or at least send me the example program or any program, which I can copy it and use it directly with a littel of modification.
Pleae help me.
Good Bye
(3,242 Views)
Hello!
I think it is the same problem like in your other two posts: "How to use pulse generation function" and "Also help in pulse generation".
So if you couldn't find the examples, descriped in the thread "How to use pulse generation function", you maybe doesn't have DAQmx installed on your system. So the next question is, do you have any hardware? The solution with two counters only works with hardware, otherwise you will not be able to to reach 0.15ms because of the windows timebase of 1ms.
Kind Regards, Christian
(3,223 Views)
