How to generate pulses with 5441
I have looked at the 5441 example and have not found an answer. I want to know whether 5441 can generate pulses.
(2,239 Views)
This device?  https://www.ni.com/en-us/support/model.pxi-5441.html
At nearly $12k, I'm sure it can generate pulses.
It is called an "arbitrary waveform generator".  I'm sure a pulse waveform is not particularly arbitrary and thus could be generated.
(2,196 Views)
Thank you very much for your answer, it helped me a lot! Can you give a VI? This helped me a lot!
(2,187 Views)
Accepted by topic author Jayson22
No.  I can't.
But look under Find Examples in the Help menu.  There are probably dozens that will show you how.
(2,182 Views)
Thank you very much, I have found the answer I want.
(2,150 Views)
