How to generate specific pattern of square wave form in lab view
I am testing an serial output adc using the Pxi machine with lab view code.
In order to test the device I need give a serial input pattern to one my pin to operate the device in particular mode.
I need to generate specific digital input pattern using Pxi and lab view .
Can anyone has any ideas or code to do that.
Thanks in advance.
(3,036 Views)
You should also be sure and go through the LabVIEW (all one word) tutorials. The paper Stuart referenced is good. When testing inkjet printheads I once used high-speed digital io to simulate an entire microprocessor bus.
Will you also be reading the device under test's output?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,998 Views)
