How to generate the files .fpgaconfig?
In a file (.vi) with FPGA items, I press 'run' and I do according to the hints, a file with extension 'lvbits' is generated. However, I don't know how to generate the file with extension 'fpgaconfig'. It is appreciated if someone can tell me. Thanks!
(3,777 Views)
Hi kanemo,
What do you need such a file for?
I use LabVIEW-FPGA for several years and never needed any "fpgaconfig" file…
(3,759 Views)
https://forums.ni.com/t5/LabVIEW/NI-PXIe-7820R-fpgaconfig-and-lvbitx-file-are-missing/m-p/3876118
You can see this web page and what I am going to do is similar with him. And you will notice there are files with extension 'lvbits' and 'fpgaconfig'.
(3,757 Views)
Hi kanemo,
so you are using VeriStand?
(3,754 Views)
Yes. So you mean that these files come from Veristand but not labview? But I do get the file with extension 'lvbits' after I run the .vi file and compile it .
(3,751 Views)
Accepted by topic author kanemo
Hi kanemo,
I guess so. As said before: I never needed/saw any "fpgaconfig" files in LabVIEW…
Yes, that's what LabVIEW does: create a lvbits file for the FPGA…
Maybe you should ask in a VeriStand forum?
(3,749 Views)
OK, I got it and thank you so much!
(3,746 Views)
