How to get Appended Array to DBL
I made a program of get Set point according to time.I want to feed set point to Arduino PWM(Analog Write).How I can connect this Build array(apppended Array) with PWM.so i can get array values one by one.Kindly Guide me.
(1,347 Views)
Use a loop with an autoindexing input tunnel...
(1,341 Views)
Thanks for Reply Sir,
But Sir,I want that its will come out as soon as ithe value come out from Sequence structure,Here Build array hold till all values come to it.Here I try to make a such Vi that can we set SetPoint with time and after set time complete its go to next time and SetPoint.So I need to connect it with PWM terminal. KIndly Guide me.
(1,278 Views)
Here I am attaching Vi,Kindly find in atttechment
(1,270 Views)
