How to get Index value when double clicked on an array
For the attached vi i when i double clicked on a selected index of the  array how to get that index value in the output
(3,473 Views)
Give this guy try.
You are using the mouse down, not the double click.  Not sure if that matters to you.  But what I ended up doing is take the Array Element Position (this is the position of the selected element), subtracting the position of the first element, and then dividing by the size of each element.  The remainder gave the element index.
(3,464 Views)
-deleted-
(3,463 Views)
