How to get Latest file from a Folder
      I would like to access latest file in a folder based upon time stamp in the file properties. Can anybody help me in this regard.
Visuman
(4,575 Views)
Hi visuman,
use ListFolder to get all filenames. Then use "File/Dir-Info" to get the "Last Changed" timestamp for each file. Sort by timestamp to find the latest file...
(4,560 Views)
Hey,
I hope this solves your problem.
If you have any questions, just ask them 🙂
Greetz, Bart
P.S. the solution is in the attachment 🙂
(4,557 Views)
Hi Bart,
- you don't need ArraySize in your snippet, autoindexing will do the job.
- using the clean up button before posting might be a good idea too. 😄
(4,551 Views)
Cleanup button was used, and you're right about the ArraySize, just common practice from other programming languages 🙂
(4,546 Views)
I could well believe it. Clean up can commonly un-clean a diagram! Smiley Very Happy
note that your output "element" will just be the latest filename, not the filepath. As you don't provide the path as an input, but generate it internally from a dialog, the path is therefore lost when calling this code as a subVI, so you should also provide the root path as an output. And rename 'element' to 'filename' and 'max value' to 'timestamp' perhaps.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(4,502 Views)
