How to get TDMS properties and how to use them once you have them?
I have a TDMS file that has 8 previously set properties that I need to get and use as parameters for various actions.
I am using the TDMS Get Properties function and am almost certain I am hooking the 'property names' and property values' ports up incorrectly. Currently, I have an array of strings attached to the names port that lists every property name I am attempting to get. To the values port, I have a build array function. How do I effectively get property names and values from a TDMS file?
Also, once I have these property values, how do I go about using them?
Thank you for your help!
(2,695 Views)
Katho,
This article may help you understand how to use and set the properties, as well as a general understanding of the TDMS file format in general.  Feel free to ask any more questions and I will be glad to assist you.
http://www.ni.com/white-paper/3539/en
J Newk
Systems Engineer
(2,667 Views)
