How to get Waveform Graph's cursor position in LabVIEW PDA 7.1?
LabVIEW PDA module support cursor. In my code(PocketPC 2003), I can only see the cursor's position in screen. I try to get the current cursor's coordinate(position) in my code.
Property node is not surported in LabVIEW PDA module. Then how to get Waveform Graph's cursor position in LabVIEW PDA 7.1?
(8,083 Views)
There is currently not a way to interface the cursor with the data. Maybe have the user select a numeric X value which is then matched to the closest data point in your array. This would potentially allow you to perform the same operations.
-Brett
(8,073 Views)
Are cursor properties still unavailable (ie in LV 8.5)?  It would be great to be able to move cursors and get data points from an XY plot.
(7,930 Views)
You are correct, this feature is still unavailable.
Nick R
NI
(7,849 Views)
