How to get a VI to communicate with a VI on another computer?
As a final project for a data acquisition I am developing a small meteorological station on one computer and getting it to communicate with another VI on a different computer, and I am lost as to how I go about doing that. I know about using shared variables to communicate across VI's, but I do not know how to use them to communicate across computers over a WiFi connection.
Any help/advice would be much appreciated.
(3,205 Views)
I like to use the Network Streams, because the communication loss/recovery is kind of automatic. If you use simple TCP/IP VIs, you have to implement those features yourself.
Here is a description: http://www.ni.com/white-paper/12267/en/
(3,202 Views)
I second the Network Streams.  My second choice would be using the STM library, which is a library built on top of the TCP/IP API.  I despise Network Published Shared Variables (nothing but problems for me).
(3,182 Views)
As a further comment on Network Streams - although they will auto-recover, they need to be terminated and restarted if you intentionally close one end.
For example, if you have a "server" (perhaps the meteorology station) and a "client", and your client connects to the server to read some data, then disconnects, you cannot restart the VI on the client and reconnect to the same connection - the server must terminate the stream and start a new one, then wait for connection.
GCentral
(3,129 Views)
And to continue on with that thought...
This is also why it is a good idea to have a "watchdog".  The idea there is that you send a NOOP command back and forth every so often.  So if you get a timeout, that means the other side likely disconnected or got lost in its own processes.  Therefore, you close the connection when you get a timeout error.  Yes, you should also close the connection if you get an error saying the other side disconnected.
(3,106 Views)
