How to get a image file from keysight oscilloscope
Please help to get/save a screen capture image file to PC from oscilloscope by Labview.
I could save a file to pc but it can not open. I think my program needs a function colored red? but I don't know the way in labview.
Keysight manual for python
# Download the screen image.
screen_bytes = do_query_ieee_block(":DISPlay:DATA? PNG")
# Save display data values to file.
f = open("screen_image.png", "wb")
f.write(screen_bytes)
f.close()
Message 1 of 11
(5,062 Views)
Hi Nimy,
In the end you just use VISARead - and apply all the information given in the programmer manual for your scope!
Most often you receive a length indicator (number of bytes) and then you can read that number of bytes using another VISARead.
Then you save the bytes, but without their prepended length indicator!
In your image you request a fixed number of bytes, which is rather uncommon for PNG files. It also is not clear if you handle TermChars correctly…
Message 2 of 11
(5,034 Views)
Exactly which oscilloscope are you using here?
Judging from the function name (do_query_ieee_block), the data is being transferred using a "data block" protocol.  The reply would start with a # followed by a number character that states the number of characters in the length, followed by that number of characters which tells you the number of bytes in the data block, and finally the block of raw data.
Here is my code for reading a data block.  The "Query" is just a VISA Write followed by a VISA Read.
And here are the contents of the Read Binary:
Message 3 of 11
(5,029 Views)
What model oscilloscope? Have you searched for any LabVIEW "Drivers"?
Most modern scopes' Labview driver sets have a VI for retrieving waveforms either as a screen copy (Image) or x/y numeric values.
=== Engineer Ambiguously ===
Message 4 of 11
(4,983 Views)
If you already grabbed the trace as data, you could plot the data on a graph and take grab the graph as a picture.  (There are Vis that can take a snapshot of a control and make a picture out of it.)
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(4,960 Views)
Hi all,
Thanks for reply.
I have tried to ideas you gived but I could not make it work well.
It seems the png file has collect hex about header and footer now.
What should I add more?
Best regards.
Message 6 of 11
(4,892 Views)
My OSC is DSO-X 2004A. I didn't find the vi for screen shot.
Message 7 of 11
(4,877 Views)
Hi Nimy,
why do you convert raw data (U8 array) to string? And why do you delete "0D0A" from your raw data?
Message 8 of 11
(4,871 Views)
Hi GerdW,
That' to delete CRLF...but now it's unnecessary.
That was adjustment for problem which was added unintentional some hexes by binary editor I used, sorry.
But I tried again without "delete CRLF" block, but still not work well.
Message 9 of 11
(4,848 Views)
Accepted by topic author Nimy2022
I was able to save a png file to my pc, and here's how to do it.
Thanks for advices.
I have additional questions,
- how can I count the picture size in reading?
- "What's this?" block
Nimy
Message 10 of 11
(4,817 Views)
