How to get a menu selection from a right click menu?
Greetings all!
Goal: To create a runtime right click menu item for displaying in hex or ascii in a string indicator.  (the same way it's available in the developer mode)
So far:
I have used the "shortcut Menu editor" to create the menu items for a string indicator "Dispay Hex" "Display ASCII"
I have a event registered to that indicator for the event "Shortcut Menu Activation?"
Problem:
However, i'm at a loss as to how to retrieve whatever menu item I select.   The Getmenuselection generates an error that halts the program.
Additionally I would like to have a check box next to the correct selection depending on how the information in the indicator is displayed.
--Eximo
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,467 Views)
Have you tried in that way?
Andrey.
(3,465 Views)
In addition - you don't need to handle Shortcut Menu Activation?. Normally you need this if you want to add some items dynamically, like this:
(3,463 Views)
What about putting the check next to the menu item?  How is that accomplished?
-Regards
eximo
Neuronetrix
(3,451 Views)
What do you want the check to represent?
It sounds like you are looking more for a radio button control.
Tim
GHSP
(3,443 Views)
If you mean "Checked" mark, use Set Menu Item Info:
(3,428 Views)
