How to get a steady input signal
Hello. I am getting a signal in from an instrument that shows steady on my analog meter but it goes between values rapidly. I put a 1-second timer on it but it will still jump from say 80 volts, to 82 volts, to 79 volts............. . I put a scope on it, just to see and it shows a steady DC value. I tried using a "Round to nearest", thinking that would stabalize it but it doesn't. Any ideas?
Thank you.
Message 1 of 11
(4,291 Views)
What you want to achieve is moving average, have a look at the VI here and adapt it for you.
http://www.ni.com/example/25082/en/
Message 2 of 11
(4,285 Views)
Again, you provide little information. What is the instrument? How are you reading it? Where is your code?
Message 3 of 11
(4,282 Views)
Agilent 4263B LCR Meter. Analog input to a USB-6002. Using double precision floating point.
Message 4 of 11
(4,261 Views)
Can you attach it as a snippet, please?
As mentioned earlier, you probably just need to do some averaging, just like a meter does. I'm also curious why you are using a fairly inaccurate 6002 instead of reading the instrument directly with RS232.
Message 5 of 11
(4,228 Views)
Snippet attached. This is just a Vi I am testing with.
curious why you are using a fairly inaccurate 6002  Lol, I didn't select it. It is a proof of concept sort of a thing however, expecting movement in the micron's, this DAQ device may not be sufficient for even proof of concept.
instead of reading the instrument directly with RS232.  For my project, it will read from RS-232, this is merely a test. It will be reading the same sort of signal from an amplifier. I just couldn't bring amp home with me.
Message 6 of 11
(4,183 Views)
Since everything is hidden in that subVI, I cannot comment any further.
Message 7 of 11
(4,177 Views)
I attached my actual project, if that will help. Thank you
Message 8 of 11
(4,048 Views)
When I open it it doesn't have a Vi on it, at least not from what I see.
Message 9 of 11
(4,045 Views)
I have tried this a number of times but the only thing I can find on averaging requires a waveform. All I have is a table of data.
Message 10 of 11
(4,035 Views)
