How to get a temperature measurement file?
Hi!
I'm new using Labview. I have a DAQcard-AI-16E-4 and Labview 7. I'm using some K thermocouples and I need to do some temperature measurements. So far I have been able to get a chart with the readings. But I just cannot create a file with my measurements. What can I do? Thank you = )
(2,374 Views)
Look at the file VIs in the file I/O palette (3 from the top on the right, has an icon of a diskette). There you have Write to spreadsheet file, which will probably do what you want.
___________________
Try to take over the world!
(2,366 Views)
