How to get a value from a string?
Hello folks
I'm heaving trouble to get a valeu from a string.
I got a code here on the forum to read temperature and pressure (current) and it get's me a 2D string array.
I want to use those values to connect to indicators but I can't connect to them as a string...
What I have is in the following image... I'm getting only integer number from the string.
How can I solve this?
(3,850 Views)
I'm guessing you are in Europe?  The comma (,) is your decimal separator?  Try using "%.;%.5f" as your string format.  This will tell the Scan From String to use the decimal point as the separator.
(3,835 Views)
EUREKA!
It worked! Thank's alot.
PS: I'm from Brazil Smiley Happy
(3,821 Views)
Same rules as Europe, just in in SW Hemisphere.  When dealing with anything international, you really have to watch out for those decimal separators.
(3,817 Views)
