How to get a verticle scrolling chart?
I need to create a chart that has data flowing vertically from the top down.  I know I can do a work-around by creating a graph with a buffer that behaves like a chart, but I'm wondering if there isn't a simpler way.  The only chart modes I see are for horizontal data flow and not verticle.
Ryan
(2,718 Views)
Accepted by topic author Ryan_McGee
There isn't anything built into LabVIEW, so you will have to make it yourself. See here for an example.
(2,699 Views)
Ryan_McGee wrote:
I need to create a chart that has data flowing vertically from the top down. The only chart modes I see are for horizontal data flow and not verticle.
Maybe do you need a chart with the vertical scrollbar? If so, it is not available in LV.
- Partha ( CLD until Oct 2027 🙂 )
(2,694 Views)
