How to get array data from .udl database file
Hi all,
I've created a database (udl) file and written three arrays as columns to a table in that database file. Then I want to get those arrays again and use them in a vi. I've built a vi but it only gets the first element of the array. I can't get the whole column. Could you please show me a way to get that array? I've attached two files that I've built.
Any help will be appreciated.
Emre
Actor Framework rocks!
Emre TUZUNER
(3,236 Views)
Accepted by topic author etuzuner
I've found the solution. I was wrong to use "Fetch Element Data". I had to use "Fetch Recordset Data". By using "Database Variant to Data" after "Fetch Recordset Data", I have 2D array of data. Then use of "Reshape Array" handled it the way I want.
Emre TUZUNER
(3,218 Views)
