How to get certain attributes of a graph?
How to get particular attributes from a graph of two variables such as Max( Y variable) and the value of X variable at the maximum point of the Y variable.
(3,536 Views)
You don't get data from a graph. You get the data from the source of the graph. Use Array Min/Max. This will return the max value and the index of it on the array. From the index you can get the x value.
(3,530 Views)
What if I want both X and Y values? I have the max value which is the max Y value and I want the X value corresponding to the Y value
(3,526 Views)
Accepted by harsha0209
I already said what you need to do to get the max y value and its index. Please try this before asking the same question.
(3,518 Views)
I got the max value and index of the Y variable from its source ( 1D array) . Now how can I obtain the value of X variable using the Index I obtained from the Array min& max???
I am sharing the VI file so that u can have a look at it.
Thanks in advance.
(3,502 Views)
Sorry, I can't look at your VI right now. If you have a voltage array, just use the index array on it with the index returned from the y array.
(3,483 Views)
