How to get data in Waveform Chart
Hi vlado,
th multiplier is related to your sample rate...
LabVIEW comes with example VIs, they also explain how to use chart and graphs with several different data types. Did you examine them?
Message 11 of 15
(1,392 Views)
Hi GerdW,
I tried my best, but I still didnt find the solution. I did it with a multiplier, but it is not precise after some period of time, because there are a lot of rounded numbers. In a 40 minutes, it gets 1 extra second.
I examine what you told be, but still have no clue how to do it. I would be very thankful if you can help me.
I would like to have an "Elapsed time reading" on the x-Axis but as a time format.
Thanks in Advance.
Message 12 of 15
(1,375 Views)
Accepted by topic author vladosaurus
Message 13 of 15
(1,371 Views)
Hi Asif138,
thank you very very very much!
Do you also know how can I put the real time into the y-Axis? so that it begins at 00:00 and ends whenever the program ends (Elapsed time is time of every process and its measured separatly)
HUGE THANKS!
Best Regards
Message 14 of 15
(1,368 Views)
check this...
only time value on y-axis
Message 15 of 15
(1,360 Views)
