How to get header in xls file
Dear All
please see attached vi.
how can i set header instead of "untitled" in both colums.
Asif Iqbal
(2,994 Views)
You need to use Set Dynamic Data Attributes function to set the signal name for each channel.
If you right click the wire, then Insert>Signal Manipulation Palette>Set Attributes.
(2,970 Views)
after this i cant see send third or onward time stamp .
please see attached..
(2,963 Views)
The vi looks exactly the same as the original one.
(2,955 Views)
it has dynamic attributes two for 2 signals
(2,953 Views)
Well, the output is the same and the VI looks the same.
Anyway, if your asking how to set the timestamp label, I actually have no idea. Might not be possible.
(2,946 Views)
see this file.
it have time value when signal was detected but no heade.
when i set dynamic data attributes then i cant get time values.
(2,942 Views)
