How to get installer created via LV project to install executables on a Vista machine which are in admin mode?
I have an installer for a program created via a LV project which installs two executables.
On Vista, only one of the executables is in admin mode.  So, I always have to right click
on the other and select 'run as administrator'.
Any way of getting both of them set to run as administrator by default?
(2,504 Views)
Do your executables include a manifest inside them or are you installing a manifest file next to your executables?
What happens if you just manually copy the executables to your system rather than installing them? Same thing, or different behavior?
-Bob
(2,474 Views)
