How to get leading zeroes in exponent of e-format
In order to mimic an ancient file specification, am trying to write DBL numbers in e-format where the exponent is padded to two digits with leading zeroes.
For example:  -1.15091E-03
Is there a simple format code that does this or do I need to write something from scratch?
(2,932 Views)
Hi Altenbach,
Are you writing the numbers to an indicator or a file?
Ipshita C.
(2,891 Views)
I am writing to a file.
(Currently, I use the following workaround: format as %12.5e, then scan the substring after the "E", format it as %+03d, and recombine with the mantissa)
(2,887 Views)
Hi Altenbach,
What you require is parsing the bits in your number to put them in your desired format. LabView does not have any parsing functions that can output in the format that you want. You can do the parsing in a dll written in C where you enforce the display of the mantissa and exponent and then call that in LabView using a Call Library Function Node. Hope this helps.
Ipshita C.
(2,847 Views)
