How to get name of sbRIO programatically
How to get "name" and "Comment" of sbRIO which I write to sbRIO-9602 in MAX in Identification box (Model, Serial number, MAC address, Name)?
(3,457 Views)
Accepted by topic author Vasek1
Use RT Get Target Information.vi located under the Utilities Palette under LabVIEW Realtime.
Christian
(3,441 Views)
That shows:
 - IP settings
      - IP adress:        136...etc.
      - DNS name:      MyMaster5                   - THAT IS WHAT I NEED, just in wrong place - in MAX it is not in IP settings, that's why i didn't searched for it there.
      - subnet mask    255.255.255.0
      - gateway          136...
      - DNS server      136...
 - MAC address        00800...
 - serial number        16....
 - system state        Running
 - model name         sbRIO-9602
 - model code          7373
 - password protected restarts?    T/F
 - halt if TCP/IP fails?                   T/F
 - locked?                                   T/F
 - use DHCP?                             T/F
Still there is no "comment" as in MAX. But that's not so important now.
I have LW Development system 2009 SP1 Profesional, Realtime Development 2009 SP1
Thanks very much!
(3,433 Views)
Dredging up a thread from the past whilst looking for something else, I thought I'd include this for posterity's sake.
To get MAX user comments for a device, initialise a session for that device, wire a property node to the System Session and select the Comment field, wire it to an indicator and then close the session. Simples.
CLA
(3,318 Views)
