How to get older value from the buffer if there is an error in read buffer?
Hi.I am trying to do serial communication with a device where i have to send command to get data. But for some procedures the data from the machine freezes. The value does not vary till that procedure is over. When I tried to send command at this time i will get error at VISA read buffer . Is there a way to get previously stored data from the buffer when an error occurs at the read buffer?
Thank you.
(3,259 Views)
Don't update your table value until you are sure you received good data.
=== Engineer Ambiguously ===
(3,242 Views)
Or how about something like this?
(see attached)
(3,235 Views)
