How to get "Item" string from my combo box?
I use a combobox where ITEMS are eg "R1234", "R7019". My VALUES for these are :"TY02" and "TZ03".
Now I select an ITEM, and the VALUE for that ITEM is output. Also, at the same time, I want ti get the String of the ITEM. How do I do this?
I tried creating a property node for the combobox ==> Strings [].
However, this is for string array, where it doesnt just only show the ITEM i want.
Please help, thanks!
(6,143 Views)
Hi xf,
you can search the string in the array to get back its index...
You can use the "strings and values" property to get both values to search for.
Message Edited by GerdW on 10-21-2009 01:15 PM
(6,135 Views)
Is that what u want to get?
Yours
RZM
(6,125 Views)
I have the same requirement of having to select from the combo box. I have labview 8.6, so the previous example didn't work on my system.
This is harder than I thought.
Waiting for help
Arjun
(5,954 Views)
