How to get "description" property of a control if control is an element of cluster?
Hi, dear All
LV provides the ability to operate with "description" property of individual VI's control. Using property nodes: VI reference > Front Panel propert > Controls[] property > Description.
Unfortunately, I didn't find a way to set or get a description of a control if it is an element of cluster =(
Could anyone suggest idea?
Thanx in advance,
Max
(3,263 Views)
Accepted by topic author maksya
interesting problem, I tried it out, have a look.
yours
RZM
(3,255 Views)
If you just want to get at a single widget inside a cluster you can go to the FP and right click on the INDVIDUAL control your are interested in and do a create property node for THAT element.
If you want to get at element in a flat cluster see the example posted by RZM.
If you want to programatically naviage into a cluster of un-known structure, then my Nugget on Exploiting Control References should be able to give you some ideas.
Have fun!
Ben
(3,243 Views)
If you don't have time to read Ben's tome (and you should read it), clusters have a Controls[] property which returns references to all the controls contained in the cluster.  You can find your control by its Label property and then get the Description property.
(3,218 Views)
bla457645, this is the quickest and most effective answer I have ever get 😃 Thank you very much.
Ben, very helpful case study. I've learned many interesting things. Thank you.
(3,192 Views)
