How to get string (specified by line and column) from txt file with labview
Hi everyone
thx
(3,062 Views)
Accepted by topic author nizartunisia
As far as I know, a text file has no columns.  Please be more specific.  Do you mean something like the 5th word on line 4, where words are separated by a space, and lines are separated by a newline character?  You could the Read from Spreadsheet String function and set the delimiter to a space.  This will produce a 2D array of strings.  Then use index array and give the line number and column number.
- tbob
Inventor of the WORM Global
(3,059 Views)
thx for you,
I find solution by using 2 functions. The 1st is "Read from text file" (count = -1 to read all of the text / !!! don't use read line ) and the second is "string subset" where just I have to specify the "offset" and the "length"of string I want to get.
Thx all of you.
Nizar.
(3,006 Views)
