How to get the 3 values that are in Output array
Hello everyone,
I want get the 3 values that are in Output array:
VATS
01:00
05:00
How to do it please?
It should be easy but I don't know how to do it yet, thanks for your help 🙂
(1,614 Views)
FYI, LabVIEW not installed in my New Laptop, So answering without viewing your code.
Have you tried using Index Array from 2D Array where you will get 1D Array of Row (All Three Values in as elements in 1D Array)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,610 Views)
Accepted by topic author ZOE_23
Hi ZOE,
use ReadDelimitedSpreadsheet file function in "string"-mode to read your CSV file.
Then use IndexArray to index the 2nd row…
(1,596 Views)
Hi @GrdW,
Thanks a lot for your answer, it works now.
Have a nice day and weekend:)
(1,588 Views)
Hi, PalanivelThiruvenkadam
Thanks your for you reply, that work now.
Have a good day and weekend:)
(1,587 Views)
