How to get the cFP IP Address?
Hi, I have a VI running standalone at a cFP 2020, and I can access the front panel using webserver. But to access these VI, I need to know the cFP 2020 IP address. This way, I'm leaving a fixed IP Adress. Now I want to put this cFP inside the company net, and, to do this, I'll select the "Obtain IP address from DHCP server" from the IP settings. But, doing it, if I know the cFP controller name, there's a way to discover the IP address?
(2,886 Views)
Try using String to IP followed by IP to String (and select dot notation). I believe the name should be resolved correctly.
___________________
Try to take over the world!
(2,868 Views)
