How to get the first folder name of path
@edjones93 wrote:
...I have created a VI which will extract all the folder names (include file name) into a string array, ....
 How is this different from the Path to array of strings function that has already been mentioned?
(Answer: Your code only works on windows, while "path to array of strings" is completely OS independent and thus highly preferred.)
Message 11 of 16
(1,655 Views)
Oh sorry, I didn't see that post, nor have I ever noticed that function node.
Message 12 of 16
(1,638 Views)
I agree, path to array of strings is not a very well know function. (However, spreadsheet string to array is useful to know.... :D)
Message 13 of 16
(1,635 Views)
Spreadsheet string to array was an option I considered but you can't control the returned data from what I'm aware, is this correct? While you can control that you input the data as a string.
Message 14 of 16
(1,618 Views)
@edjones93 wrote:
... but you can't control the returned data from what I'm aware,
Define "control"?
You define the output as a 1D array of strings by wiring the "array type" input, you define the field delimiter ("\" in this case) and you define the format of the data between the delimiters (%s in this case). What else do you want to control? Currently, it returns exactly the same as your own code. 😄
Message 15 of 16
(1,612 Views)
Too true, just tried it and you're right... Still, would be nice to know whether the original question has been answered. You can navigate the hierarchy of files with all the methodologies discussed and even further work through file structures using List Folders in the File I/O palette.
Message 16 of 16
(1,605 Views)
