How to get the history(datapoints) of 32 waveform-charts which are in one cluster?
Thanks in advance. I would like to handle up to 32 waveform-charts by using a cluster. My problem is that the datapoints of their history has to be saved if a particular event occures. How can I get the character-node for the history of a waveform-chart inside the cluster?
(2,524 Views)
I'm not certain what you are asking, but here's a suggestion. On the front panel, you can pop-up (right-click) on a waveform chart within a cluster and create a property-node (for the history), which can be manipulated as you desire on the diagram.
(2,524 Views)
