How to get the hortizontal reference line on waveform chart
Hello NI community,
Currently, I am working on a Gaussmeter to get the magnetic flux intensity data. I was getting the data and program running successfully. Now I am to make a reference horizontal lines on waveform chart at exactly at -12.5mT and at 12.5mT. I was trying to keep markers in chart but nothing is working. Did not find any useful solutions for my problem Could you please suggest how do I get horizontal line in wave form chart. Looking forward to hear from you soon.
Thanks & Regards
Vijay
(2,684 Views)
Make the Waveform Chart multiplot, bundling your constant reference values together with the measured mT.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,662 Views)
Hi
Thank you so much for your reply. I don’t need to plot multiple data in a waveform chart. I was getting data from the Gaussmeter in the form of a sinusoidal wave, just I need to create two horizontal lines for my reference in the waveform chart. I would like to create to horizontal line exactly at -12.5mT(milliTesla) and at 12.5mT(milliTesla). For your reference, I am attaching a picture of the desired chart. Could you please suggest me.
I have one more doubt in case if I use the multiplot waveform chart how do I need to connect to my program for getting the fixed horizontal line exactly at -12.5mT and at 12.5mT. I am attaching the program picture could you please check it
Vijay
(2,647 Views)
Accepted by topic author vijay0507
What I suggested is AFAIK the easiest way. You need to drop a Bundle node (Cluster palette), drag to get three inputs, then wire -12.5, 12.5 and the measured value (what gets out from the multiplication by 1000 in your vi). Then wire the output cluster to Chart.
Not clear if you want to plot with a different colour between limits.
Paolo
(2,642 Views)
