How to get the number of plots in Waveform Graph or how to iterate plots of Waveform Graph?
I am using Labview 2017
I want to make a vi which get a waveform graph refnum and set the color of the plots
I understand how to change the color of plot using the Active plot and Plot color property when I know the index of the plot
But I don`t know how to iterate all plots of the Waveform Graph when I don`t know the number of plots
Is there any way to get the number of plots or iterate over the plots
(2,363 Views)
How did the plots get into the graph in the first place?
Somewhere in the program you created the graph.  In that part you put N sets of data into the graph.  Or put in a 2D array that you can get the dimensions of.  Determine that N and pass it to the part of the program where you are dealing with the colors either using a shift register, or a value property node or a local variable.
(2,336 Views)
This is the easiest way I know of to tell the number of plots in a waveform graph.
(2,331 Views)
This is the easiest way!
(1,275 Views)
you might take a look at this very fine example, especially look at the top-level.vi and inside the "Format Plot".vi
https://forums.ni.com/t5/Example-Code/LabVIEW-Box-Plots/ta-p/3506533
(1,247 Views)
Hi Des1gnR,
Your way potentially creates very large data copies in memory just to determine an array size. And it depends on pre-defined datatypes of the graph…
Darrens example is very quick, without large data copies!
(1,229 Views)
