How to get the "integrated" FPGA I/O Property Node
I'm working with LabVIEW FPGA module using a NI-9146 chassis and NI-9234 sound and vibration module. I'm trying to set the Input Configuration for Analog Input channels in the FPGA VI. I looked up the NI 9234 example and found this "integrated" FPGA I/O Property Node. But I can't find this function in any palette. I want to use it as it's compact and easy to use. How can I get it? Attached is a screen capture of it.
The FPGA palette has the generic Property Node to which I need to connect an I/O constant.
(3,602 Views)
Accepted by topic author abvenk
Right click on the property node, go to Select Item:
(3,599 Views)
Thank you!
(3,563 Views)
Yeah, wow thank you...Why is that much harder than it needs to be. I am pretty familiar with RT/FPGA and it's not obvious- as your final selection from the mouse fly-out menu is the channel 'data' and then it changes to the module config when it appears on the diagram.
Regards
Jack
(3,443 Views)
