How to get the real-time data from a CCD camera in labview?
I am going to setup a monitor system and need to acquire the intensity of each pixel at each second from a CCD camera. Also, I need to to some simple calculations with these real-time data at every moment to get my finanl output in this monitor system.
How may I do this using Labview?
Thank you very much.
Kai
(3,517 Views)
We don't have special powers, so we can't guess if you have Imaq Vision or not, if your camera comes with a LabVIEW driver, if it has an USB interface, or firewire, or a dedicated NI card, if you just want to detect a move, or a change in intensity, etc...
So, try to be more specific with your question, that will helps a lot 😉
Chilly Charly    (aka CC)
(3,502 Views)
Sorry for that I didn't clarify my question. What I am going to measure is the intensity variation of a CCD camera. Actually, only the central 8 pixels of detector array are necessary to me, I need them to do some calculations to generate my monitor output. As mentioned, this will be a monitor system, so the read speed should be fast, at least 10 samples/second, for the operator to make correct termination of the production process.
In fact, I didn't get any element. I mean I even do not get a camera yet. Also, I am new to this field. Therefore, I need to learn if this work could be run well with Labview and all the accessories I should have.
Please give me some simple directions about how to achieve this work effectively.
Any suggestion is appreciated.
Best,
Kai
(3,474 Views)
http://www.ni.com/vision/software.htm
Start here to learn about NI machine vision solutions.  There is also a whole forum section devoted to it (select it from the GoTo... pulldown in the upper right side).
We can help you with specific questions but I don't think anyone will design a system for you. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,454 Views)
Thank you.
May I ask where I can find the forum section you mean?
I don't find the GoTo button.
Kai
(3,440 Views)
It's not actually a button.  It's the pulldown selector below the one that says: "Select Community".  You can use that to jump to the other forums.  Go to the one called "Machine Vision".
NI-IMAQ and all the other Vision products can certainly do what you want.  Specifying all the needed components and designing the system will not be a trivial matter though.  It might be best to contact your NI representative and get some advice on the subject.  Good luck!
(3,431 Views)
