How to get the simulation Time from simulink model with SIT ?
Hello
I try to get the SimulationTime from Simulink with SIT. Do you have any ideas ?
Tks a lot for your help
FB
(3,669 Views)
When you create your simulink dll, just specify an output as the simulation time and you should be able to read it from LabVIEW.
ClémentG
(3,649 Views)
Thanks for your answer, but i don't want use a dll, but the user interface NI to do cosimulation with simulink model.
I have found a solution, but it takes more than 200 ms to get time, and i try to get time at each milliseconds.
FB
(3,630 Views)
