How to get the sql query result?
Currently I am using LV2012 to connect a Oracle database server. After the installations/settings for Oracle Express and Oracle ODBC driver done.
I am sucessfully to use the SQL command to query the data through my window command prompt.
Now the problem is, how I do the same task in Labview by using the database connectivity toolkits?
I have build a VI for query as attached, but i have no idea what pallete to use to get the query result.
Please help me ~~
(3,752 Views)
Accepted by topic author TanTan
Here is a piece of code I use to test SQL commands, you can use the part that retrieves sql results.
It is also possible to get the column headers back, but that is for next lesson!
(3,745 Views)
This is how I execute a store procedure. I hope it helps.
(3,733 Views)
