How to get the value incremented only when the loop is true?
    Thanks a lot its the right solution which i needed...its working fine..
Message 11 of 12
(973 Views)
You are taking the long way with that solution, but you get where you wanted to go.
I'm glad that your problem could be solved.
Cheers,
Pattos
LabVIEW Gretchin
Message 12 of 12
(966 Views)
