How to get the windows folder dialog by LV?like photo as below
How to invoke the windows folder dialog by LV?
Pls help me to check? Thank you advance.
(4,424 Views)
That is an older style of file dialog.  I'm not sure even Windows offers that anymore.
In the File I/O palette >> Advanced File I/O, there is an express VI called File Dialog.  You can set that to select folders only.
(4,396 Views)
Accepted by topic author 都会好的
You need to use the SHBrowseForFolder win32 call.  But, as noted on the MS page, it is recommended to use IFileDialog  with the FOS_PICKFOLDERS option for Vista and later.
(4,379 Views)
 Hi, Matthew
Tks for your relpy, then, I Will  try it  again that according to your advice.
(4,349 Views)
hi Ravens,
Thank you, you shared method i coulde know how to use it.
Have a approach, i would  know how to use LV to invoke Win32 call.
(4,346 Views)
  May be this is the one you have asked as Ravens said,
Hope it helps!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(4,327 Views)
Hi  Matthew,
According to your approach that i can to be achieve it.
Thank you very much.
(4,311 Views)
