How to get total number of slider in a meter
I'm now using the meter control objects, I added 4 needles/sliders when the VI is offline, when I clicked run, Labview no longer lets me add more needle, so the needle control is not dynamic, there are several things I need to do dynamically which means let computer find and make decisio during running:
1. Find out how many sliders are on the panel?
2. Add/remove one of sliders?
3. Redistribute all sliders?
I'd like to use property node to get this done, but I didn't how. Any help?
Arnold
(3,017 Views)
Accepted by topic author mugger
we can't add needle/slider to the object during VI runtime.
your requirements 1 and 3 can be done using the property node..
Use the "Digital Display[]" property to get/set the slider value.
Ganesan Kani
(3,010 Views)
Create your meter with the maximim number of sliders you possibly need, then hide (property:visible) as many as you want to simulate fewer sliders.
(2,988 Views)
Hi Altenbach,
No property available to make specific slider visible/invisible Smiley Sad
and im able hide the slider by setting "Active Slider", "Slider Colors" properties.
I am using LV2009
Ganesan Kani
(2,977 Views)
Yes, set them to transparent. That's what I meant.
(2,968 Views)
Thanks a lot, merry christmas!
Arnold
(2,949 Views)
