How to get waveform data in specific duration?
I have an analog waveform and I want to get the data in 20ms range (Like, 0ms-20ms then 20ms-40ms .........)
How can I get that?
I have used ''get waveform subset.vi'' but it only takes the first range(0-20ms).
N.B. I already have the total waveform data, I just need to get data in range & save it.
Thanks.
(3,473 Views)
Show what you've done so far.  With Get waveform subset, you need to specify the start point and the duration.  Did you wire in both of those inputs?
(3,450 Views)
Yes, I wired both inputs.
Here is the vi.
thanks.
(3,438 Views)
But you wired them with constants!  So of course you'll get a constant output.
If you want the waveform to change, you need to update the start time in every iteration.  (0, .02, .04, .06, ........)
(3,404 Views)
Thank you for your help Smiley Happy
(3,381 Views)
