How to give the tolerance of +-5% for an Array?
I'm trying to build for developing some random values. So I took some array of data which was stored before and i want to change those values continuous values which should be in +-5% tolerance band.
for ex: Array- 10,20,30,40,50
I need the output as +-5% from the above values. Can anyone help me out with some suggestions?
(4,497 Views)
Accepted by topic author dhanushmh
Tools you need:
- For Loop which iterates as often as you have elements in your array (array size)
- Random Number to get a random number between 0 and 1. Scale the number to a value between -0.05 and +0.05. Inside the loop
- Add the scaled random number to 1. Use an indexing tunnel to create an array with numbers between 0.95 and 1.05
- Multiply the original array with the random number array
Norbert
Expert: Geometry
(4,475 Views)
Like this?
(4,459 Views)
What if it's a 2D array?
(4,419 Views)
Then you have to nest the for loop in another for loop. The array size of the original array is giving you the numbers of rows and columns so you know how often each of the loop has to run.
Norbert
Expert: Geometry
(4,415 Views)
