How to guarantee an event structure executes at least once
I have an event structure that I want to execute one time on program start and then behave normally after that.  Is there an *elegant* way to do that?
Lee Jay
(2,761 Views)
on startup set the timeout to some number and put your code you wish to run inside the timeout case. then inside the time out case set it to -1 using a shift register.
Joe.
"NOTHING IS EVER EASY"
(2,758 Views)
That works.  And it's not as ugly as what I was going to do.
Thanks!
Lee Jay
(2,753 Views)
Jhoshkins' idea will work, but if you want the timeout to continue to function (not wait forever) you can put your code inside the True case of a True/False case structure, and use the First Call? to select it.
PaulG.
Retired
(2,749 Views)
I had timeout at forever anyway so this works just fine.
Lee Jay
(2,744 Views)
