How to guess the software package containing a certain lvlib?
I'm trying to open a project, but when it loads, it asks me to find NI_FpgaMspHost.lvlib. I have wasted 2 days installing LabView software like crazy, but no matter what I install, this library is never found. Is there a tool I can use to find which software package provides this library?
(2,977 Views)
What version of LabVIEW are you using?  What all did you install?
In newer versions of LabVIEW, if you look at the context help of a missing subVI, it will tell you if it was from a missing NI toolkit.
And that library appears to be part of the LabVIEW FPGA module.
GCentral
(2,941 Views)
I'm using Labview 2013 SP1 f2, with LabView FPGA 13.0.1, Xilinx tools 14.4, etc...
I'll try the context help tip, thanks!
(2,930 Views)
