How to have variable manipulation in double For Loop in LabView?
I am novice to LabView programming. I have a portion of code written in Basic language (refer enclosed attachment), which I would like to convert to LabView block diagram. It seems to be little complicated, but I would like to know how to do this in LabView. Any help in this regard will be appreciated. Thanks in Advance.
(2,987 Views)
Attached is sample code to get you started. If you need to use a variable more than once all you need to do is to to pass the data by wire. Check here for aditional information on how to proceed.
(2,987 Views)
