How to highlight all child items in a tree control?
I have a tree control and a boolean button. I want to use the button to select all (highlight) the child items in the tree control. I've seen CVI functions where you can set the active items, but such a function/method does not appear in LabVIEW.
Any clues?
"All truths are easy to understand once they are discovered; the point is to discover them." -- Galileo Galilei
Message 1 of 8
(3,975 Views)
Since tree controls don't support multi-item-selection, you cannot select multiple items.
This leaves the question if you want to 1) highlight the items just to display actual valid items or 2) if you want to use multiple items.
If 1) is correct, you should delete all items and insert programmatically only the ones valid. Leaving items which are not valid in the current context is not good programming style.
If 2) is correct, please read the first sentence again...
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(3,973 Views)
I'm not sure which tree control you're using, but I'm using LabVIEW 8.2.1 and when you right click on the control, there is a selection mode section with the following options
  • 0 or 1 item
  • 1 item
  • 0 or more items
  • 1 or more items
The last two options allow you to select multiple items.
Message 3 of 8
(3,967 Views)
You are correct, i misread the last both options...
There is indeed no simple way to select child-items programmatically since you don't know if an item is "child" or "parent".
You can select multiple items by passing multiple values per propertynode, so if you generate a fitting array, the correct items are selected. Maybe this is a kind of workaround for you...
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(3,962 Views)
I can programmatically get all the child items. My problem is actually showing them as selected in the control on the screen so that a person can then drag those items to another tree control.
Message 5 of 8
(3,955 Views)
Look at this piece of code:
If you can make sure, that the retrieved tags are the children, that should work for you, too.
hope this helps,
Norbert
Message Edited by Norbert B on 08-20-2008 10:57 AM
Norbert
Expert: Geometry
Message 6 of 8
(3,940 Views)
Hi settles,
Once you have all the children, you just need to set the value of the tree control to be an array of all the child tags.  Here's a screenshot of a VI that does this:
First I get all the tags, then I get the parent of each tag.  If the parent is a non-empty string, I add it to an array.  Then I write that array value to a local variable of the tree control.  Let me know if you have any questions on this method.  I believe the "All Tags" property I'm using was added in LabVIEW 8.0.
-D
Message Edited by Darren on 08-20-2008 10:58 AM
Message 7 of 8
(3,937 Views)
Thank you. I thought setting the value of the control actually change its contents.
Message 8 of 8
(3,928 Views)
