How to identify FP object is control or Indicator in runtime?
Hi all
Is there any way to know programmatically that front panel object is control or indicator?
ALso what are the ways to convert the indicator text changing on runtime into the different languages.
(2,658 Views)
Accepted by topic author LV_user1
@LV Coder wrote:
Hi all
Hi
Use the property node of the front panel object to know if it is an indicator or control. Set the property to 'Indicator' in order to get your info. Use the Context help for this property for more details.
Regards
Freelance_LV
TestAutomation Consultant
(2,657 Views)
